Your qt-based wayland images, such as the ones created with qt5-wayland-examples/Dockerfile
coming from the bullseye branch are not starting due to a missing bash.
When following your QT Debian for Torizon tutorial and starting the weston container with
docker run -d --rm --name=weston --net=host --cap-add CAP_SYS_TTY_CONFIG \ -v /dev:/dev -v /tmp:/tmp -v /run/udev/:/run/udev/ \ --device-cgroup-rule='c 4:* rmw' --device-cgroup-rule='c 13:* rmw' --device-cgroup-rule='c 226:* rmw' \ torizon/weston:$CT_TAG_WESTON --developer weston-launch --tty=/dev/tty7 --user=torizon
and starting the qt container with
# docker run --rm -it --name=qt5 \ -v /tmp:/tmp \ -v /dev/dri:/dev/dri --device-cgroup-rule='c 226:* rmw' \ torizon/qt5-wayland-examples:$CT_TAG_QT5_WAYLAND_EXAMPLES
these for instance result in
torizon/qt5-wayland-examples->docker: Error response from daemon: OCI runtime create failed: container_linux.go:345: starting container process caused "exec: \"|1\": executable file not found in $PATH": unknown.
The current workaround: starting the last container with
docker run --rm -it --entrypoint=bash --name=qt5-14-2 \ -v /tmp:/tmp \ -v /home/torizon/:/home/torizon/ \ -v /dev/dri:/dev/dri --device-cgroup-rule='c 226:* rmw' \ torizon/qt5-wayland-examples:$CT_TAG_QT5_WAYLAND_EXAMPLES
which considers the flag --entrypoint=bash
But obviously this is not intended by you since all the images having $CT_TAG_QT5_WAYLAND_EXAMPLES=1
and other branches having $CT_TAG_QT5_WAYLAND_EXAMPLES=2
are starting correctly as described in the tutorial.
