I am trying to build and deploy a simple form application using QT creator to Colibri T20.
I have created Image Version 2.8.2 version image and sdk build using openembedded system from toradex repository.
I have installed new image in Target and sdk in the host and configured QT as per toradex page for QT.
Everything seems ok. only exception is i the kits Tab of Options in QT it shows a red astrix and pop up says mkspec not found. I have pointed out the mkspecs as mentioned in the setting up page.
The build succeeds. Here is the output.
16:30:03: Running steps for project QT_Project1...
16:30:03: Starting: "/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/qt5/qmake" /home/ub_serpent_host/QT_Projects/QT_Project1/QT_Project1.pro -r -spec /usr/local/oecore-x86_64/sysroots/armv7at2hf-vfp-angstrom-linux-gnueabi/usr/lib/qt5/mkspecs/linux-oe-g++
16:30:03: The process "/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/qt5/qmake" exited normally.
16:30:03: Starting: "/usr/bin/make"
/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/qt5/uic ../QT_Project1/mainwindow.ui -o ui_mainwindow.h
arm-angstrom-linux-gnueabi-g++ -mfpu=vfpv3-d16 -march=armv7-a -mthumb -mfpu=vfp -mfloat-abi=hard --sysroot=/usr/local/oecore-x86_64/sysroots/armv7at2hf-vfp-angstrom-linux-gnueabi -c -pipe -O2 -pipe -g -feliminate-unused-debug-types -O2 -Wall -W -D_REENTRANT -fPIC -DQT_NO_DEBUG -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I../QT_Project1 -I. -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-vfp-angstrom-linux-gnueabi/usr/include/qt5 -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-vfp-angstrom-linux-gnueabi/usr/include/qt5/QtWidgets -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-vfp-angstrom-linux-gnueabi/usr/include/qt5/QtGui -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-vfp-angstrom-linux-gnueabi/usr/include/qt5/QtCore -I. -I. -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-vfp-angstrom-linux-gnueabi/usr/lib/qt5/mkspecs/linux-oe-g++ -o mainwindow.o ../QT_Project1/mainwindow.cpp
arm-angstrom-linux-gnueabi-g++ -mfpu=vfpv3-d16 -march=armv7-a -mthumb -mfpu=vfp -mfloat-abi=hard --sysroot=/usr/local/oecore-x86_64/sysroots/armv7at2hf-vfp-angstrom-linux-gnueabi -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -Wl,-O1 -o QT_Project1 main.o mainwindow.o moc_mainwindow.o -L/usr/local/oecore-x86_64/sysroots/armv7at2hf-vfp-angstrom-linux-gnueabi/usr/lib -lQt5Widgets -lQt5Gui -lQt5Core -lGLESv2 -lpthread
16:30:03: The process "/usr/bin/make" exited normally.
16:30:03: Elapsed time: 00:01.
Then I am trying to deploy to target. Here is the output.
16:31:47: Connecting to device...
16:31:47: The remote file system has 717 megabytes of free space, going ahead.
16:31:47: Deploy step finished.
16:31:47: No deployment action necessary. Skipping.
16:31:47: Elapsed time: 00:01.
Nothing reaches the target.
Then I try to copy the executable to target using SD card and try to run from command prompt.
Then it says
error while loading shared libraries: libqt5Widgets.so.5
cannot open shard object file
no such file..
Why my deployment module is not packing those libraries? or is that libraries needed in target?
How to proceed? please help.
