Qt 5.15.5 lts on bsp 5.x
Is it possible to build qt 5.15.5 lts on bsp 5.x ?
I’m currently deciding if I should upgrade to the current boot2qt branch or stay at bsp 4.
Hi @jhowrez!
You can see from this article Qt for Device Creation (Boot to Qt) | Toradex Developer Center the supported versions.
LTS Qt 5.15.5 is based on BSP 4.
But, for a customer with Yocto knowledge (which is a must-have for using Boot to Qt), it should not be super hard to support additional Toradex SoMs. The Qt Company provides How to add support for a new device | Boot to Qt documentation | Qt 6.9.2
E.g. to build an SDK fully compatible with Qt Creator - which they call QBSP, one can refer to Customizing QBSP content | Boot to Qt documentation | Qt 6.9.2
Thanks @henrique.tx for the reply!
Makes sense, I guess I’ll try to update my application to qt6!
