QSQLITE driver not loaded
Hello!
We already had a rdk board by phytec with a qt application using a sqlite database (I just had to add sqlite to IMAGE_INSTALL_append), but for some reasons we switched to toradex now. As I could see, sqlite3 is already included in the console-trdx-image, so it should work out of the box (certainly, i had to add the qt libs). So this is, what my IMAGE_INSTALL_append looks like now:
IMAGE_INSTALL_append = " qtbase qtbase-plugins qtbase-fonts qtdeclarative qtdeclarative-plugins qtserialport qtwebsocket"
I also tried adding sqlite (→ the old version 2), but whenever I start our application, I always get the following error:
QSqlDatabase: QSQLITE driver not loaded
QSqlDatabase: available drivers:
QSqlDatabase: an instance of QCoreApplication is required for loading driver plugins
However, i can open the database file on the console with sqlite3 dbfile.db, so sqlite seems to be installed properly. I think Qt just cannot find the driver libary, but I don’t know how to fix this.
Systeminfo:
CoM: Toradex Colibri iMX6 Solo 256MB | V1.0A
SBC: Viola Plus | V1.2A Plus
Image: console-trdx-image
Version: 2.6 / v2015.12 / jethro / 2.0
Hi
You are missing the Qt5 backend for sqlite.
The Qt5 Yocto recipe allows a fine grained control over enabled feature with the PACKAGECONFIG mechanism. By default a lot of those features are not enabled.
You could try to add ‘sql-sqlite’ to PACKAGECONFIG from within conf/local.conf by adding:
PACKAGECONFIG_append_pn-qtbase = " sql-sqlite"
and then rebuild the image.
Max
YOU ARE MY HERO! It worked! Thank you very much! :slight_smile:
is there any other way, without building an image??
No.
Note also our partner network, some of which offer services to build an image/SDK or application to your specification.
Hi @max.tx
I am facing the same problem. I have already added ‘sql-sqlite’ to PACKAGECONFIG from within conf/local.conf by
and also sqlite in IMAGE_INSTALL_append but still Qt is giving me following message.
What can be the problem.
Thank You in advance
HI @Tony_Stark
Could you provide the version of the hardware and software of your module?
Which repo branch did you use to compile?
Hardware SoM: Toradex Colibri imx7 dual 1GB Colibri
Colibri Evaluation board V3.2B
Image: Angstrom-LXDE-Image
Colibri-iMX7-eMMC_LXDE-Image-Tezi_2.8b6-20191226
Version: 2.8/ v2017.12 / rocko / 2.4
Hi @Tony_Stark
Can you check and upload the following log files:
/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/qtbase/5.9.8+gitAUTOINC+82eb6aa08e-r0/temp/log.do_configure
/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/qtbase/5.9.8+gitAUTOINC+82eb6aa08e-r0/temp/run.do_configure
Is the sqlite flag really set? Did you add sqlite or sqlite3 to your IMAGE_INSTALL? Please make sure it is sqlite3.
Stefan
Hi stefan_e.tx Yes !!! It worked when I was following the article
“How to setup Qt Creator on Toradex” in the article you have given following syntax
+PACKAGECONFIG_append_pn-qtbase = " sql-sqlite" I just copy pasted that,And compiled the image but there were no sqlite driver library in it,But when I removed that + sign and again recompiled then the sqlite driver library is there,And my application is working good.I request you to please make the change in the article.alt text
I have attached the screenshot of the article,Please go through to it.
Hi @Tony_Stark
I see what you mean but the + is on purpose. This is how a diff file looks like:
I will check if we can change the syntax there.
Stefan
I Got QSqlDatabase : QSQLITE driver not loaded using qt5.15.0 sources .
created file qtbase_%.bbappend
PACKAGECONFIG_append = " sql-sqlite"
Included above line my issue is solved.
Hi @sateesh
Thanks for your valuable Input.
