Will be it possible to use the QNX BSP of the NXP-IMX95-EVK board to use it in Verdin -IMX95-IVY+ ?
Based on the available information, QNX BSP support for the Verdin iMX95 is currently under development (1). The documentation indicates that for Verdin iMX95, QNX BSP availability is marked as “Coming Soon!” (1).
Toradex does not generally provide support for QNX BSP, and customers need to access QNX BSPs directly from QNX by visiting the QNX Board Support Packages library and choosing Toradex as the board vendor (1).
While both the NXP iMX95 EVK and Verdin iMX95 use the same NXP i.MX95 SoC (2), BSPs are typically developed and validated for specific hardware configurations. The Ivy Plus carrier board has its own hardware layout and peripheral configurations that may differ from the NXP EVK reference design.
For the most accurate information about BSP compatibility between the NXP iMX95 EVK and Verdin iMX95 with Ivy Plus carrier board, I recommend:
The expectation is that a featured BSP for Verdin iMX95 will be ready for release in the future, but specific timelines are not available in the current documentation.
Hi Ramesh,
As explained by Toradex AI Assistant, you are talking about two different HW platforms. So almost for sure they need different QNX BSPs.
Yu Liang
Toradex
