Qmake.exe not found when building linux image 2.6 using amstrong distribution
qmake.exe not found when building linux image 2.6 using amstrong distribution. I use linux image 2.6 and sync then running bitbake commands as given by “OpenEmbedded (core) - Toradex System/Computer on Modules” then the meta tool chain is build as given by “Qt Creator to cross compile - Embedded Linux” but atlast there is no qmake executable file inorder to continue the process. Can anyone please give a solution.
The referenced pages provide several different options on what to build. So what were the exact bitbake commands you used.
Note that all options do target Linux as the build host. The qmake binary will be called qmake or qmake2, certainly not qmake.exe.
