Python3-pysqlite3 not found in apalis-imax8-dunfell branch
Hello team,
I have an Apalis-Imax8QP device running Yocto Dunfell. I am attempting to execute a Python script designed to read data from a SQLite3 database and process it. However, when I run the Python script, it throws the following error:
import sqlite3
ModuleNotFoundError: No module named ‘sqlite3’
Hi @vinodg,
Thanks for writing to Toradex community.
To completely understand your question do share BSP and complete hardware details.
Let us assume you are running tdx-reference-multimedia-image which does have python3 in default image so that allows you to run python script.
import sqlite3
  • So to solve this issue you will need to build yocto image with python3-pip
  • python3-pip by default is not part of reference image.
  • Once you build image with python3-pip, this will enable to install packages using pip.
  • Also it depends if sqilite package do not need cross compiling then it should install fine using pip install command.
Let me know if you have further queries.
Ritesh Kumar
