Can’t get PWM working on a Ixora/T30 under WinCE 1.4 final. Used the C# example for PWM and changed the MXM pins to:
public const Int32 PWM_A = 2; //59; //PWM_A at SODIMM pin 59
public const Int32 PWM_B = 4; //28; //PWM_B at SODIMM pin 28
public const Int32 PWM_C = 6; //30; //PWM_C at SODIMM pin 30
public const Int32 PWM_D = 8; //67; //PWM_D at SODIMM pin 67
Connected pin X27.33 to an Oscilloscope and set all PWM outputs to 50Hz/50 duty cycle. But nothing changes. When I use the Toradex GPIO Config V2.4 and change pullstate from MXM3.2 to pullup or pulldone I see changes on my Oscilloscope.
With VB.net we have an init Function with the following function calls:
(GPIO Lib was initialised previously)
(getSODIMMPin returns the same as your public constants)
Function initPWMEasy(ByVal pwm As Integer) As Boolean
Dim prescale As Integer = 64
Dim period As Integer = 256
Dim altFn As Integer = 0 ' 0 = PWM -1 = GPIO
GPIO.SetPinAltFn(getSODIMMPin(pwm), altFn, GPIO.DIR_OUT) 'Set SODIMM Pin xx as Output'
GPIO.SetPinLevel(getSODIMMPin(pwm), True) 'Set default level LOW'
GPIO.SetPinDir(getSODIMMPin(pwm), True)
'MsgBox("Init PWM" & pwm.ToString & " = " & getSODIMMPin(pwm))
InitPWM(pwm, prescale, period)
SetPWMDutyPercentage(pwm, 0)
PWMEngine = pwm
End Function
It works fine, but have not tried with 50Hz only. If i would have programmed todas, the PWMChannel would be an enum I use it with the Apalis T30, WINCE7 1.4 and IXORA Board.
I think the altFN could be wrong.
I hope it could help you a bit, Have a nice Weekend, Best Regards, Stefan
Now it works. Problem was altFunctionA was set to 1 instead of 0 in the PWM example of Toradex.
So I had to change the following part (additionaly to the MXM numbers):
else if (procID == Constant.TYPE_TEGRA3) ///< T30
channelA = 0;
channelB = 1;
channelC = 2;
channelD = 3;
altFunctionA = 0; //<-- Original Toradex example set to 1
altFunctionB = 0; //<-- Original Toradex example set to 1
altFunctionC = 0; //<-- Original Toradex example set to 1
altFunctionD = 0; //<-- Original Toradex example set to 1
prescale_1 = Constant.TEGRA3_PRESCALE_50Hz;
prescale_2 = Constant.TEGRA3_PRESCALE_100Hz;
prescale_3 = Constant.TEGRA3_PRESCALE_500Hz;
prescale_4 = Constant.TEGRA3_PRESCALE_1kHz;
prescale_5 = Constant.TEGRA3_PRESCALE_2kHz;
prescale_6 = Constant.TEGRA3_PRESCALE_5kHz;
Thank you Stefan.P for the example that pointed me to the correct direction.
