Pulling image from local registry fails
* Executing task: DOCKER_HOST=192.168.188.24:2375 LOCAL_REGISTRY=192.168.188.20 TAG=arm64 GPU=-am62 DEBUG_SSH_PORT=2231 DEBUG_PORT1=2232 DEBUG_PORT2= DEBUG_PORT3= docker compose pull slinttest-debug
WARN[0000] The "DOCKER_LOGIN" variable is not set. Defaulting to a blank string.
[+] Pulling 1/1
! slinttest-debug Warning Get "https://192.168.188.20:5002/v2/": net/http: request canceled while waiting... 15.1s
WARNING: Some service image(s) must be built from source by running:
docker compose build slinttest-debug
1 error occurred:
* Error response from daemon: Get "https://192.168.188.20:5002/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)
* The terminal process "/bin/bash '-c', 'DOCKER_HOST=192.168.188.24:2375 LOCAL_REGISTRY=192.168.188.20 TAG=arm64 GPU=-am62 DEBUG_SSH_PORT=2231 DEBUG_PORT1=2232 DEBUG_PORT2= DEBUG_PORT3= docker compose pull slinttest-debug'" terminated with exit code: 1.
I’m on Windows using the Torizon WSL. I can access the local registry from my windows install by visiting either http://192.168.188.20:5002/v2/ or http://localhost:5002/v2/.
However inside the Torizon WSL install curl http://192.168.188.20:5002/v2/ hangs forever whereas curl http://locahost:5002/v2/ responds correctly.
I tried following along with this issue Docker container registry not running - #11 by nimble-william but killing the process just kills the registry.
sudo tdx-info
Software summary
Bootloader: Unknown
Kernel version: 6.6.87.1-microsoft-standard-WSL2 #1 SMP PREEMPT_DYNAMIC Mon Apr 21 17:08:54 UTC 2025
Kernel command line: initrd=\initrd.img WSL_ROOT_INIT=1 panic=-1 nr_cpus=14 hv_utils.timesync_implicit=1 console=hvc0 debug pty.legacy_count=0 WSL_ENABLE_CRASH_DUMP=1
Distro name: NAME="TorizonOS"
Distro version: VERSION_ID=1.0.0
Distro variant: VARIANT=Docker
Hostname: NL-ENS-L-100046
cat: /sys/devices/virtual/dmi/id/board_name: No such file or directory
cat: /sys/devices/virtual/dmi/id/board_vendor: No such file or directory
cat: /sys/devices/virtual/dmi/id/board_version: No such file or directory
cat: /sys/devices/virtual/dmi/id/board_serial: No such file or directory
Hardware info
HW model:
Toradex version:
Serial number: -
Processor arch: x86_64
