I am facing an issue with the toradex vs code extension to pull a container.
My configuration is :
Iris v2 carrier board + imx8dx 1gb wb
I am currently having a Qt (c++/qml) project workspace on Vs code. All the development set up is done, using the toradex extension and working in a dev container.
My board is correctly connected through ssh and recognized.
My problem is :
When I try to debug my code, using the “start debbuging” button (or F5), I can see in the output logs :
[02-29 13:47:49.425] Pulling weston (torizon/weston-vivante:2)…
Thank you very much. Looks like i had a connexion issue (no network) on the board.
Fixed it.
Now I have some kind of new issue when I try to run my app : Failed to create wl_display (No such file or directory) qt.qpa.plugin: Could not load the Qt platform plugin “wayland” in “” even though it was found. This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
