I need the TK1 pins 200 and 204 pulled-high after poweron. I compiled u-boot with following in board/toradex/apalis-tk1/pinmux-config-apalis-tk1.h
static const struct tegra_gpio_config apalis_tk1_gpio_inits[] = {
/* port, pin, init_val */
GPIO_INIT(A, 2, IN),
GPIO_INIT(A, 3, IN),
static const struct pmux_pingrp_config apalis_tk1_pingrps[] = {
/* pingrp, mux, pull, tri, e_input, od, rcv_sel */
PINCFG(DAP2_FS_PA2, HDA, UP, NORMAL, INPUT, DEFAULT, DEFAULT),
PINCFG(DAP2_SCLK_PA3, HDA, UP, NORMAL, INPUT, DEFAULT, DEFAULT),
static const struct pmux_drvgrp_config apalis_tk1_drvgrps[] = {
When I check the pin levels in u-boot they seem to be not pulled up:
Apalis TK1 # gpio input A2
gpio: pin A2 (gpio 2) value is 0
Apalis TK1 # gpio input A3
gpio: pin A3 (gpio 3) value is 0
