So I am running a custom Linux build (Kirkstone) on an Apalis iMX6Q
root@acu3:~# uname -r
6.0.5-rt14-6.1.0-devel+git.040e3123e9d9
On the network I have a Microsemi TP4100 PTP Grandmaster clock. What I am attempting to do, is sync the Linux system clock to this PTP, which should be pretty straight forward.
On my Linux workstation (Ubuntu 22) that is on the same network, the following works like a charm
mmorgan@mmorgan-edev-workstation2:~$ sudo ptp4l -i enp6s0 -m
[sudo] password for mmorgan:
ptp4l[69154.335]: selected /dev/ptp0 as PTP clock
ptp4l[69154.336]: port 1: INITIALIZING to LISTENING on INIT_COMPLETE
ptp4l[69154.336]: port 0: INITIALIZING to LISTENING on INIT_COMPLETE
ptp4l[69154.675]: port 1: new foreign master 00b0ae.fffe.08c3cc-2
ptp4l[69158.676]: selected best master clock 00b0ae.fffe.08c3cc
ptp4l[69158.676]: updating UTC offset to 37
ptp4l[69158.676]: port 1: LISTENING to UNCALIBRATED on RS_SLAVE
ptp4l[69161.675]: master offset -18185848 s0 freq +32752 path delay 2354
ptp4l[69162.675]: master offset -18186136 s1 freq +32464 path delay 2354
ptp4l[69163.675]: master offset -7328 s2 freq +25136 path delay 2354
ptp4l[69163.675]: port 1: UNCALIBRATED to SLAVE on MASTER_CLOCK_SELECTED
ptp4l[69164.675]: master offset 608 s2 freq +30874 path delay 2354
ptp4l[69165.675]: master offset 1751 s2 freq +32199 path delay 2392
ptp4l[69166.675]: master offset 2073 s2 freq +33046 path delay 2390
ptp4l[69167.675]: master offset 1443 s2 freq +33038 path delay 2390
ptp4l[69168.675]: master offset 682 s2 freq +32710 path delay 2392
ptp4l[69169.675]: master offset 625 s2 freq +32858 path delay 2403
ptp4l[69170.675]: master offset -244 s2 freq +32176 path delay 2493
ptp4l[69171.675]: master offset 322 s2 freq +32669 path delay 2415
ptp4l[69172.675]: master offset 169 s2 freq +32613 path delay 2418
ptp4l[69173.675]: master offset -438 s2 freq +32056 path delay 2420
ptp4l[69174.675]: master offset 441 s2 freq +32804 path delay 2420
ptp4l[69175.675]: master offset -106 s2 freq +32389 path delay 2579
You can see the frequency adjusting as expected and the master offset is nearing zero. I am assuming that the Yocto built Linux should work in essentially the same way. However,
root@acu3:~# ptp4l -i eth0 -m
ptp4l[171761.198]: selected /dev/ptp0 as PTP clock
ptp4l[171761.214]: port 1: INITIALIZING to LISTENING on INIT_COMPLETE
ptp4l[171761.217]: port 0: INITIALIZING to LISTENING on INIT_COMPLETE
ptp4l[171762.602]: port 1: new foreign master 00b0ae.fffe.08c3cc-2
ptp4l[171766.602]: selected best master clock 00b0ae.fffe.08c3cc
ptp4l[171766.608]: updating UTC offset to 37
ptp4l[171766.610]: port 1: LISTENING to UNCALIBRATED on RS_SLAVE
ptp4l[171768.602]: master offset -28299683372754529 s0 freq +0 path delay 32052307
ptp4l[171769.601]: master offset -28299684550743588 s0 freq +0 path delay 210042759
ptp4l[171770.602]: master offset -28299685554201248 s0 freq +0 path delay 213499027
ptp4l[171771.601]: master offset -28299686667470060 s0 freq +0 path delay 326769231
ptp4l[171772.603]: master offset -28299687667471451 s0 freq +0 path delay 326769231
ptp4l[171773.602]: master offset -28299688610834957 s0 freq +0 path delay 270134129
ptp4l[171774.602]: master offset -28299689610836349 s0 freq +0 path delay 270134129
ptp4l[171775.602]: master offset -28299690610834956 s0 freq +0 path delay 270134129
ptp4l[171776.603]: master offset -28299691618586828 s0 freq +0 path delay 277884609
ptp4l[171777.602]: master offset -28299692618585436 s0 freq +0 path delay 277884609
ptp4l[171778.603]: master offset -28299693618586827 s0 freq +0 path delay 277884609
ptp4l[171779.602]: master offset -28299694618585435 s0 freq +0 path delay 277884609
ptp4l[171780.603]: master offset -28299695618586827 s0 freq +0 path delay 277884609
ptp4l[171781.602]: master offset -28299696618585434 s0 freq +0 path delay 277884609
ptp4l[171782.603]: master offset -28299697531954762 s0 freq +0 path delay 191252545
As you can see, the locking never occurs. I am assuming that this is because ptp4l is unable to manipulate the PHC on the PHY. I have tried various different configurations for ptp4l and profiles and nothing works.
What am I missing here, is there some device tree configuration needed to manipulate the PHC. I have ensured that the gpsd, ntpd, and chronyd daemons are not running. I have the following in my kernel config,
CONFIG_NET_PTP_CLASSIFY=y
# PTP clock support
CONFIG_PTP_1588_CLOCK=y
CONFIG_PTP_1588_CLOCK_OPTIONAL=y
# end of PTP clock support
CONFIG_NETWORK_PHY_TIMESTAMPING=y
CONFIG_PHYLIB=y
CONFIG_SWPHY=y
# CONFIG_LED_TRIGGER_PHY is not set
CONFIG_FIXED_PHY=y
CONFIG_MICREL_PHY=y
CONFIG_MICROCHIP_PHY=m
CONFIG_PPS=y
# CONFIG_PPS_DEBUG is not set
# PPS clients support
# CONFIG_PPS_CLIENT_KTIMER is not set
CONFIG_PPS_CLIENT_LDISC=y
CONFIG_PPS_CLIENT_GPIO=y
# PPS generators support
I am at a complete loss here and any help would be greatly appreciated.
