Prune unreferenced images after a successful update
I know I can use torizon cloud to update my applications described in a docker-compose.yml.
During the update, all the new images are pulled from the container registry an so on the SoM there are:
  • images and containers referenced by the new docker-compose.yml
  • images and containers no more referenced by the new docker-compose.yml
As far as I understand, the containers are deleted by the docker-compose service with the -–remove-orphans
But what about the images?
This comment sounds me suspicious.
Can someone clarify, please?
Based on the documentation, yes, Torizon OS does automatically prune unreferenced images after successful application updates(1). The system implements a comprehensive cleanup process to manage storage space.
Application Update Process and Image Cleanup
During application container updates, Torizon OS performs the following sequence(1):
  1. Source the new container images - runs docker-compose pull --no-parallel on the new docker-compose.yml(1)
  2. Stop old containers - runs docker-compose -p torizon down on the old docker-compose.yml(1)
  3. Start new containers - runs docker-compose -p torizon up --detach --remove-orphans on the new docker-compose.yml(1)
  4. Clean up unused resources - executes docker system prune -a --force to clean up any unused containers, networks, and images from the device(1)
Automatic Image Pruning
The final step in the update process specifically addresses your concern about unreferenced images. The system runs docker system prune -a --force which removes(1):
  • Unused containers
  • Unused networks
  • Unused images (including those no longer referenced by the new docker-compose.yml)
This ensures that images from previous application versions that are no longer needed are automatically cleaned up, preventing storage bloat on your device.
Manual Pruning
You can also manually trigger this cleanup process at any time using the docker system prune command(2):
# docker system prune
This will remove all stopped containers, unused networks, dangling images, and dangling build cache(2).
The automatic pruning during updates ensures your system maintains optimal storage usage without manual intervention.
Greetings @vix,
If you take a look at the commit that added that comment you have the full context in which it was written: Do not perform Docker image pruning in some error cases · toradex/aktualizr@af04707 · GitHub
We use docker system prune -a --force in order to prune containers and images from the system during an update: aktualizr/src/torizon/dockercompose_secondary/compose_manager.cc at toradex-master · toradex/aktualizr · GitHub
In typical cases this should removed any unused containers and images. However, this affects even images referenced by the current compose file if the containers were short-lived enough and exit before the cleanup command is executed, as the commit I referenced stated. The comment was in reference to improving this specific behavior.
Do you have short-lived containers in your setup that result in the corresponding images being removed? Or did you actually observe any other strange behavior that led to your question here?
Yes, I have two short-lived containers in my setup and I saw something strange in some rare circumstances. For this reason I started a wide-spectrum investigation.
Both of the containers are used to copy files from the container itself to the host and then they close:
  • the first one copies a lot of files (images, configurations, …) and so this take a while
  • the second one copies the cortex-m firmware so that uboot can load it at the next boot
I know that both of these needs should be handled with “subsystems” and not containers. And, maybe, this kind of scenarios are the reason why Toradex decided to implement subsystems.
But subsystems didn’t exist yet when we setup this specific couple of containers and I prefer not to change them now (maybe in future release of my application).
I’m not saying that the prune is the reason for the issue I see sometimes. Now I understand better and I can go on with my investigation.
Well if you don’t have any other questions regarding this specific point, then I’m glad I was able to help clarify.
