I would like to ask for some help to programm some VF61 with the Evaluation Board and a SD-Card. The last time we programmed those modules was in 2022.
I have to setup the computer with all the needed tools to program them. I am facing some problems at the moment, because our documentation was made for an old cygdrive and an old pyhton version.
Is there an actual script and a documentation. like the vfxx-produciton.py script made for W11 and python3 etc.
I just have to copy the image from the SD Card to the module.
For Linux-based systems, I’d recommend using Toradex Easy Installer, which is the modern, streamlined approach for flashing modules. This eliminates the need for custom Python scripts and works with current tools.
Could you please confirm:
Which OS are you installing (Linux/Torizon or WinCE)?
Which version specifically?
This will help me provide you with the most accurate, up-to-date procedure for your use case.
Unfortunately, Toradex Easy Installer is not available for the Colibri VF61 module. The VF61 is a NAND-based module that predates Easy Installer support.(1)
For your Colibri VF61 V1.2B with a Linux-based system, you’ll need to use the traditional NAND flashing method. Here’s what you need to know:
Flashing Process for VF61
The Colibri VF61 uses NAND Flash for storage and requires the MTD subsystem and UBIFS.(2)
Since you mentioned needing to “copy the image from the SD Card to the module,” you have two main options:
Use U-Boot commands to flash from SD card (boot into U-Boot, load files from SD, and flash to NAND partitions)
Update from running Linux userspace - though note that Toradex does not officially support this method for production(2)
Important Note
The official and only supported method for installing an entire image into the VF61 is through U-Boot-based flashing procedures, not Easy Installer.(2)
Could you clarify:
Do you have access to the U-Boot console on your modules?
What Linux BSP version are you targeting?
This will help me provide more specific flashing instructions for your setup.
partition layout is incorrect for VF. Single u-boot copy on VF Colibries and partition layout never included 2nd u-boot copy. Though VF supports redundant boot copies, and single u-boot partition is enough to hold two copies, you need as well to program some fuse to let VF ROM look for 2nd copy at right place. Doable, I did in the past.
