I am having some trouble with pulling an Image from the local Docker Registry (on the Host pc) when called from the Toradex module. This only happens on my pc as my colleagues don’t experience this problem and use the same vs code project (we are using dev containers with the Torizon IDE extension and a .NET codebase).
Two weeks ago this was not giving any problems when I first tried it, but now something has changed and I can’t pull images from the registry anymore
The error is Error response from daemon: Get “http://10.101.10.47:5002/v2/”: net/http: request canceled (Client.Timeout exceeded while awaiting headers) and is returned when calling
LOCAL_REGISTRY=10.101.10.47 TAG=arm64 docker compose pull em-sdc-a53-debug
Our setup:
- Custom carrier board with Verdin imx8m-mini (10.101.30.40)
- Latest Torizon OS
- Host PC with ip: 10.101.10.47
- Docker on host pc with registry on port 5002 (generated by project in vs code)
What we already tried:
- My colleagues can access the same Verdin module and pull an image from the registries on their respective pc’s
- They can’t pull an image from the registry on my pc
- I connected to my colleagues network switch to check if my switch was the problem => still didn’t work
- Disabled firewall
- Uninstalled Docker Desktop and reinstalled it
- Removed registry and rebuilt it from vscode
- Checked wireshark loggings to see whats happening (added the wireshark log below)
From the wireshark loggings it seems I get a lot of TCP errors and not all HTTP communication is present that I see when comparing with a wireshark logging of my colleagues when they pull the image from their pc’s.
test4.pcapng (50.9 KB)
Can someone help me with this problem? Because at the moment I am stuck with this problem as I can’t debug my code. I can provide more info if/when needed.
