I’m struggling getting a rust container with Bluer to work. Bluer requires libdbus-1-dev to be installed, but this is where I am running into problems. I used the rust template from the TorizonIDE, but when trying to install the packages libdbus-1-dev:arm64 and pkg-config:arm64 (via apt-get), I get
2.396 E: Unable to locate package pkg-config:arm64
2.396 E: Unable to locate package libdbus-1-dev:arm64
When installing these packages in other applications it was no problem, so I suspect something with the base image, since this is the main difference.. Can anyone help me out here?
Dockerfile.sdk
# ARGUMENTS --------------------------------------------------------------------
# Board architecture
ARG IMAGE_ARCH=
# Base container version
ARG SDK_BASE_VERSION=1.84-bookworm
# Directory of the application inside container
ARG APP_ROOT=
# BUILD ------------------------------------------------------------------------
FROM rust:${SDK_BASE_VERSION}
ARG APP_ROOT
ARG IMAGE_ARCH
RUN apt-get -q -y update && \
apt-get -q -y install \
gcc-arm-linux-gnueabihf \
gcc-aarch64-linux-gnu \
# ADD YOUR PACKAGES HERE
# DO NOT REMOVE THIS LABEL: this is used for VS Code automation
# __torizon_packages_build_start__
pkg-config:arm64 \
libdbus-1-dev:arm64 \
# __torizon_packages_build_end__
apt-get clean && apt-get autoremove && \
rm -rf /var/lib/apt/lists/*
RUN rustup target add aarch64-unknown-linux-gnu && \
rustup target add armv7-unknown-linux-gnueabihf
ARG UNAME=torizon
ARG UID=1000
ARG GID=1000
RUN groupadd -g $GID -o $UNAME
RUN useradd -m -u $UID -g $GID -o -s /bin/bash $UNAME
USER $UNAME
WORKDIR ${APP_ROOT}
Hello Tim,
Thank you for reaching out with your question. It seems like you’re encountering issues with installing libdbus-1-dev and pkg-config for the ARM64 architecture in your Rust container. This is likely due to the way the packages are specified in your Dockerfile.
Here are some steps you can take to resolve this:
Remove Architecture Suffixes: In your Dockerfile, try removing the architecture-specific suffixes from the package names. Instead of pkg-config:arm64 and libdbus-1-dev:arm64, simply use pkg-config and libdbus-1-dev. The package manager should automatically handle the architecture based on the environment.
Verify Base Image Compatibility: Ensure that the base image you are using (rust:${SDK_BASE_VERSION}) supports the ARM64 architecture. If it doesn’t, consider using a multi-architecture base image or a Torizon base image that is already configured for ARM64.
Check Package Availability: Make sure that the packages you are trying to install are available for the ARM64 architecture in the Debian repositories. You can verify this by checking the package lists or using a tool like apt-cache.
By following these steps, you should be able to resolve the package installation issues in your Rust container. If you have any further questions, feel free to ask.
Toradex AI Assistant
The issue here is that the base image is not configured to find and install packages from other architectures. The base image here is coming from the official rust container image. In the base images that come from Toradex we run RUN dpkg --add-architecture ${CROSS_TARGET_ARCH} when building the container like so: torizon-containers/cross-toolchain/base/Dockerfile at stable · torizon/torizon-containers · GitHub
This allows the following apt commands to locate and install packages for other architectures. Try adding this to your SDK Dockerfile before the apt commands and it should work when installing arm64 packages.
