I’m working with a Goodix GT911 touchscreen. When tests are performed on TorizonCore 6.2.0 we are able to use the touch device everything runs smoothly.
The problems start when we use TorizonCore 5.7.2+build 21, we are not able to see device on i2c channel.
As you can see, the device is not switching between the address 4f and 5d, we already checked the hardware, however we didn’t find why our device does not work in torizoncore5.
Are there any error logs related to the Goodix driver shown in the output of dmesg?
About the device tree overlay you showed, is it the complete overlay, or just a part of it? I ask this because I couldn’t find any node label called gt911 in the Verdin iMX8M Mini device tree in the kernel source.
One last question: You mentioned you got the touchscreen working on TorizonCore 6.2.0. Is there any specific reason that is keeping you on 5.7.2 instead of just using 6.2.0?
I’m working with a Goodix GT911 touchscreen too, but I’m using Yocto to generate my image. I faced a similar problem, I wasn’t able to see my device on i2c channel.
Then I discovered that sometimes Goodix uses register address 0x14. I think you can try to add another node with that register, maybe it’s going to work.
