I am using Apalis iMX6Q on an Apalis Evaluation Board and I am trying to generate a tezi-compatible image.
I successfully build an image that I could write on a SD card and everything was well until “I” discovered the need to use the eMMC and from here the party started.
There would’ve been no problem whatsoever if I didn’t need to have a custom kernel (based on a quite old one - 4.19) on my system.
I tried to add in local.conf:
IMAGE_CLASSES_append = " image_type_tezi"
PREFERRED_PROVIDER_virtual/kernel = "linux-customed"
include conf/machine/include/${MACHINE}.inc
and in custom-image.bb
# Show Tezi EULA license
TEZI_SHOW_EULA_LICENSE ?= "1"
TEZI_SHOW_EULA_LICENSE_apalis-tk1 ?= "0"
TEZI_SHOW_EULA_LICENSE_use-mainline-bsp ?= "0"
TEZI_SHOW_EULA_LICENSE_colibri-imx6_use-mainline-bsp ?= "1"
TEZI_SHOW_EULA_LICENSE_apalis-imx6_use-mainline-bsp ?= "1"
IMAGE_CLASSES += "image_type_tezi"
IMAGE_FSTYPES_append = " teziimg"
I know I have some redundancy here but this is not the problem. The real problem is that building now (after these changes) I SOMEHOW end up with the mainline kernel (5.4.193)
I have tried to comment from local.conf
include/conf/machine/include/${MACHINE}.inc
This gets me this error:
ERROR: mprouter-full-cmdline-1.0-r0 do_image_teziimg: Error executing a python function in exec_python_func() autogenerated:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_python_func() autogenerated', lineno: 2, function: <module>
0001:
*** 0002:rootfs_tezi_run_json(d)
0003:
File: '/home/user/workspace/yocto/meta-toradex-bsp-common/classes/image_type_tezi.bbclass', lineno: 343, function: rootfs_tezi_run_json
0339: uboot_file = d.getVar('UBOOT_BINARY_TEZI_RAWNAND')
0340: artifacts += " " + d.getVar('KERNEL_IMAGETYPE') + " " + d.getVar('KERNEL_DEVICETREE')
0341: elif flash_type == "emmc":
0342: use_bootfiles = oe.types.boolean(d.getVar('TEZI_USE_BOOTFILES'))
*** 0343: flash_data = rootfs_tezi_emmc(d, use_bootfiles)
0344: uenv_file = d.getVar('UBOOT_ENV_TEZI_EMMC')
0345: uboot_file = d.getVar('UBOOT_BINARY_TEZI_EMMC')
0346: # TODO: Multi image/raw NAND with SPL currently not supported
0347: uboot_file += " " + d.getVar('SPL_BINARY') if d.getVar('OFFSET_SPL_PAYLOAD') else ""
File: '/home/user/workspace/yocto/meta-toradex-bsp-common/classes/image_type_tezi.bbclass', lineno: 154, function: rootfs_tezi_emmc
0150: })
0151: bootpart_rawfiles.append(
0152: {
0153: "filename": d.getVar('UBOOT_BINARY_TEZI_EMMC'),
*** 0154: "dd_options": "seek=" + (offset_spl if offset_spl else offset_bootrom)
0155: })
0156:
0157: if use_bootfiles:
0158: filesystem_partitions.append(
Exception: TypeError: must be str, not NoneType
I also tried to leave the include/conf/machine/include/${MACHINE}.inc from local.conf and modify conf/machine/include/apalis-imx6.inc as:
MACHINE_NAME = "Apalis-iMX6"
KERNEL_DEVICETREE += "imx6q-apalis-ixora-v1.2.dtb"
KERNEL_DEVICETREE_use-mainline-bsp += " \
imx6q-apalis-eval.dtb \
imx6q-apalis-ixora-v1.1.dtb \
#PREFERRED_PROVIDER_virtual/kernel = "linux-toradex"
#PREFERRED_PROVIDER_virtual/kernel_preempt-rt = "linux-toradex"
PREFERRED_PROVIDER_virtual/kernel_preempt-rt = "linux-customed"
PREFERRED_PROVIDER_virtual/kernel_use-mainline-bsp = "linux-toradex-mainline"
PREFERRED_PROVIDER_virtual/kernel_use-mainline-bsp_preempt-rt = "linux-toradex-mainline"
PREFERRED_PROVIDER_virtual/dtb_use-mainline-bsp ?= "device-tree-overlays-mainline"
but I still end up with the mainline kernel.
Any ideas on how can I make it work please? it drives me nuts ![]()
