I have a problem with uploading Linux via USB. After executing a series of writes (after executing the commands run setupdate, run update), the T30 module stops responding - i.e. after displaying the “resetting …” message, the module reset is not performed. After a manual reset of the module, nothing appears in the console (gtkterm). Please help.
Log:
U-Boot 2016.11-2.8.7+g5c2d46b325 (Jun 10 2020 - 17:22:21 +0000)
SoC: tegra30
Reset cause: SW_MAIN
DRAM: 1 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
In: serial
Out: vidconsole
Err: vidconsole
Model: Toradex Colibri T30 1GB IT V1.1B, Serial# 06624164
USB recovery mode, disabled autoboot
Net: No ethernet found.
Colibri T30 # run setupdate
MMC: no card present
** Bad device mmc 1 **
starting USB...
USB0: USB EHCI 1.00
USB1: USB EHCI 1.00
USB2: USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 1 for devices...
Warning: asix_eth MAC addresses don't match:
Address in SROM is 00:0e:c6:87:72:01
Address in environment is 00:01:02:03:04:05
2 USB Device(s) found
scanning bus 2 for devices... 2 USB Device(s) found
reading flash_blk.img
710 bytes read in 22 ms (31.3 KiB/s)
## Executing script at 81000000
reading colibri_t30/flash_blk.img
5083 bytes read in 30 ms (165 KiB/s)
enter "run update" to update the entire module
Colibri T30 # run update
switch to partitions #1, OK
mmc0(part 1) is current device
MMC read: dev # 0, block # 2047, count 1 ... 1 blocks read: OK
MMC read: dev # 0, block # 4095, count 1 ... 1 blocks read: OK
MMC read: dev # 0, block # 8191, count 1 ... 1 blocks read: OK
MMC read: dev # 0, block # 16383, count 1 ... 1 blocks read: OK
MMC read: dev # 0, block # 32767, count 1 ... 1 blocks read: OK
MMC read: dev # 0, block # 65535, count 1 ... MMC: block number 0x10000 exceeds max(0x8000)
0 blocks read: ERROR
MMC read: dev # 0, block # 131071, count 1 ... MMC: block number 0x20000 exceeds max(0x8000)
Total of 3 byte(s) were the same
reading colibri_t30/colibri_t30.img
535040 bytes read in 81 ms (6.3 MiB/s)
MMC write: dev # 0, block # 0, count 1045 ... 1045 blocks written: OK
reading colibri_t30/mbr.bin
512 bytes read in 24 ms (20.5 KiB/s)
switch to partitions #0, OK
MMC write: dev # 0, block # 0, count 1 ... 1 blocks written: OK
reading colibri_t30/boot.vfat
16777216 bytes read in 1649 ms (9.7 MiB/s)
MMC write: dev # 0, block # 8192, count 32768 ... 32768 blocks written: OK
reading colibri_t30/zImage
4221896 bytes read in 445 ms (9 MiB/s)
writing zImage
4221896 bytes written
reading colibri_t30/tegra30-colibri-eval-v3.dtb
** Unable to read file colibri_t30/tegra30-colibri-eval-v3.dtb **
reading colibri_t30/root.ext3-100
67108864 bytes read in 6501 ms (9.8 MiB/s)
MMC write: dev # 0, block # 40960, count 131072 ... 131072 blocks written: OK
reading colibri_t30/root.ext3-101
67108864 bytes read in 6503 ms (9.8 MiB/s)
MMC write: dev # 0, block # 172032, count 131072 ... 131072 blocks written: OK
reading colibri_t30/root.ext3-102
67108864 bytes read in 6508 ms (9.8 MiB/s)
MMC write: dev # 0, block # 303104, count 131072 ... 131072 blocks written: OK
reading colibri_t30/root.ext3-103
67108864 bytes read in 6497 ms (9.9 MiB/s)
MMC write: dev # 0, block # 434176, count 131072 ... 131072 blocks written: OK
reading colibri_t30/root.ext3-104
67108864 bytes read in 6502 ms (9.8 MiB/s)
MMC write: dev # 0, block # 565248, count 131072 ... 131072 blocks written: OK
reading colibri_t30/root.ext3-105
67108864 bytes read in 6492 ms (9.9 MiB/s)
MMC write: dev # 0, block # 696320, count 131072 ... 131072 blocks written: OK
reading colibri_t30/root.ext3-106
MMC write: dev # 0, block # 827392, count 131072 ... 131072 blocks written: OK
reading colibri_t30/root.ext3-107
67108864 bytes read in 6500 ms (9.8 MiB/s)
MMC write: dev # 0, block # 958464, count 131072 ... 131072 blocks written: OK
reading colibri_t30/root.ext3-108
67108864 bytes read in 6496 ms (9.9 MiB/s)
MMC write: dev # 0, block # 1089536, count 131072 ... 131072 blocks written: OK
reading colibri_t30/root.ext3-109
67108864 bytes read in 6480 ms (9.9 MiB/s)
MMC write: dev # 0, block # 1220608, count 131072 ... 131072 blocks written: OK
reading colibri_t30/root.ext3-110
MMC write: dev # 0, block # 1351680, count 131072 ... 131072 blocks written: OK
reading colibri_t30/root.ext3-111
58720256 bytes read in 5672 ms (9.9 MiB/s)
MMC write: dev # 0, block # 1482752, count 114688 ... 114688 blocks written: OK
resetting ...
Iris 1.1B
Linux 2.8.7
