I have a Problem with update tool. When I start update.exe /rc or /r or /rc2000. After I have made a backup (with update.exe /b [path] or a restore (with update.exe /u [path]) there is no Restart possible with the Arguments /rc or /r. Device shut down, but does not start again.
What could that be?
Dear @JanP
I wasn’t able to reproduce the problem. Can you please give me some more details, so I can try to setup my environment equal to yours:
Do you use the built-in update.exe?
If no, where is your update.exe file located, and which version is it?
What peripherals did you connect to the Ixora? I connected only
a parallel TFT display
a USB Mouse/Keyboard in the vertical USB connector X7
Please provide detailed steps (one option) to reproduce the problem I prefer testing with the backup option, because this does not change the module configuration, e.g.
Boot WEC2013
Open a command shell
enter \> update /b \backup.bak, wait until it finishes, then update /rc
Once the system is blocked, does it reboot after a hardware reset or power-cycle?
Does the failure happen each time, or only “1 out of N times” ?
Do you use any custom registry settings, or is the registry still in factory-default state?
