I am trying to update the device tree for using the Colibri iMX6DL with a capacitive display and I’m going through the steps in the Build U-Boot and Linux Kernel from Source Code instructions to see if I can get it to work. Everything is appearing to work fine until I get to the U-boot configuration section.
The instructions where it says I need to have the sysroot defined do no work. I am getting the following error when I run the command make CC='arm-angstrom-linux-gnueabi-gcc --sysroot=${HOME}/oe-core/build/out-glibc/sysroots/colibri-vf'.
make: arm-angstrom-linux-gnueabi-gcc: Command not found
I’m obviously missing something here.
I’m also having a problem with the command cp ~/u-boot-toradex/u-boot.imx /media///. I’m getting the following error because the file does not exist under the u-boot-toradex folder.
cannot stat '/home/chemtrac/u-boot-toradex/u-boot.imx': No such file or directory.
Can you give me an idea of why the file u-boot.imx was not created? Everything appeared to extract and install in previous commands, so I’m not sure what I might have missed.
This only applies in case you opted for the second option using the alternative toolchain from a previous OpenEmbedded build as explained here.
Yes, you should have installed and configured your toolchain before as noted in above given link.
Well, u-boot.imx should get built but as you do not have the toolchain setup properly it failed doing that.
