Hi
I have a problem with the gstreamer package installed on BSP 6.4
I tried to find opusenc / opusdec plugins gstreamer . the “gst-inspect-1.0” show that it doesn’t have these two plugins.
Then I think about installing a package from gstreamer to have them.
so I checked with
As we can see, opus is actually not enabled. You can enable it by:
modifying directly the gstreamer1.0-plugins-base inside of openembedded-core folder. Although this might be the quickest way, it is not the recommended approach.
creating a bbappend for the recipe with your modifications.
The modification should be to simply append the opus to the contents of PACKAGECONFIG of gstreamer1.0-plugins-base recipe.
Hi and thanks for your Reply.
Could you please help me on `bbappend’?
That would be great let me how and have a sample
by add this to local.conf it will ok?
