I am currently facing a problem with timedated and hopefully someone can give me the right hint to solve my issue.
Problem:
Using a newer kernel version breaks the systemd startup of timedated. timedatectl returns a timeout.
Starting /lib/systemd/systemd-timedated manuelly works. Going back to the old kernel on the same system does not solve the problem. If the new kernel has started one time the service keeps broken.
Old Kernel
Linux verdin-imx8mm 5.4.91-33073-g5c94c062e0ab #8 SMP PREEMPT Fri Apr 9 11:15:43 CEST 2021 aarch64 GNU/Linux
root@verdin-imx8mm:~# timedatectl
Local time: Tue 2021-05-11 05:28:29 UTC
Universal time: Tue 2021-05-11 05:28:29 UTC
RTC time: Tue 2021-05-11 05:28:30
Time zone: Universal (UTC, +0000)
System clock synchronized: yes
NTP service: active
RTC in local TZ: no
New Kernel
Linux verdin-imx8mm 5.4.115-34753-g342aacb61faa #10 SMP PREEMPT Mon May 10 16:30:28 CEST 2021 aarch64 GNU/Linux
Failed to query server: Connection timed out
root@verdin-imx8mm:~# systemctl status systemd-timedated.service
* systemd-timedated.service - Time & Date Service
Loaded: loaded (/lib/systemd/system/systemd-timedated.service; static; vendor preset: disabled)
Active: failed (Result: resources)
Docs: man:systemd-timedated.service(8)
man:localtime(5)
https://www.freedesktop.org/wiki/Software/systemd/timedated
May 11 05:50:51 verdin-imx8mm systemd[1]: systemd-timedated.service: Failed to run 'start' task: Not a directory
May 11 05:50:51 verdin-imx8mm systemd[1]: systemd-timedated.service: Failed with result 'resources'.
May 11 05:50:51 verdin-imx8mm systemd[1]: Failed to start Time & Date Service.
May 11 05:52:18 verdin-imx8mm systemd[1]: systemd-timedated.service: Failed to run 'start' task: Not a directory
May 11 05:52:18 verdin-imx8mm systemd[1]: systemd-timedated.service: Failed with result 'resources'.
May 11 05:52:18 verdin-imx8mm systemd[1]: Failed to start Time & Date Service.
