When attempting to build the SDK via bitbake with:
bitbake tdx-reference-minimal-image -c populate_sdk
I get :
ERROR: nativesdk-util-linux-2.35.1-r0 do_package: QA Issue: nativesdk-util-linux: Files/directories were installed but not shipped in any package:
/opt/tdx-xwayland/5.4.0/sysroots/x86_64-tdxsdk-linux/lib
/opt/tdx-xwayland/5.4.0/sysroots/x86_64-tdxsdk-linux/lib/systemd
/opt/tdx-xwayland/5.4.0/sysroots/x86_64-tdxsdk-linux/lib/systemd/system
/opt/tdx-xwayland/5.4.0/sysroots/x86_64-tdxsdk-linux/lib/systemd/system/fstrim.service
/opt/tdx-xwayland/5.4.0/sysroots/x86_64-tdxsdk-linux/lib/systemd/system/fstrim.timer
Please set FILES such that these items are packaged. Alternatively if they are unneeded, avoid installing them or delete them within do_install.
nativesdk-util-linux: 5 installed and not shipped files. [installed-vs-shipped]
ERROR: nativesdk-util-linux-2.35.1-r0 do_package: Fatal QA errors found, failing task.
ERROR: Logfile of failure stored in: /home2/dallas/projects/obc-2023/build/tmp/work/x86_64-nativesdk-tdxsdk-linux/nativesdk-util-linux/2.35.1-r0/temp/log.do_package.454184
ERROR: Task (virtual:nativesdk:/home2/dallas/projects/obc-2023/build/../layers/openembedded-core/meta/recipes-core/util-linux/util-linux_2.35.1.bb:do_package) failed with exit code ‘1’
I believe this must be some problem with:
/meta-toradex-bsp-common/recipes-core/util-linux/util-linux_%.bbappend
Am I over the target? I’ve tried specifying FILES_${PN} (also the new syntax FILES:${PN}) but doesn’t seem to help. I’m out of ideas at this point so any clues would be appreciated.
Thanks - Dallas
Colibri-imx8
Viola Carrier
Linux BSP 5.4.0
