I have a problem to run RS485 interface on Colibri evaluation board.
What I would like to achieve is:
Running two-way communication with master <> multi slave configuration, where Colibri is master device.
Network configuration: RS485 2W speed 9600 8N1.
Steps I did to achieve that target:
I set jumpers on Evaluation board in that way:
JP16 closed - to disable RS232
JP11 closed - echo off
JP13 closed JP15 closed - for 2W option
JP12 open
JP14 closed - to use only one 120ohm resistor on network
Then I connected to pins 4, 5 two USB<>RS485 converters connected to my pc.
When I send message from Colibri I can easily read it on both USB<>RS485 converters, also message from one converter is received on other converters.
But when I try to read message on Colibri board with command cat < /dev/ttymxc1 & entire RS485 network is broken, I can no longer send data between USB<>RS485 converters.
When I try to send data from Colibri it is sent without a problem and received ok on all devices. Also when I enable echo by JP11 jumper, data sent from Colibri is echoed to its interface.
I connected logic analyzer to UARTB pins on the evaluation board, and also to DB9 pins of rs485 interface. I found that when I execute command cat < /dev/ttymxc1 & output UART_B_RTS is changed to low state, then on rs485 network, one line is in permanent low state thus no other device on network can send data.
I was also trying to use minicom running in docker container but there was also a similar issue after turning it on - RS485 network was down.
I was trying everything that comes to my mind but without success, could you help me in this problem?
