I have downloaded the latest version of the Toradex CE Libraries for VF61 (V1.7.3275) but I have problem with reading the help file Toradex_CE_Libraries.chm I see only the structure of this help. Is this file defective?
As noted on the download page of libraries here → Toradex CE Libraries and Code Samples | Toradex Developer Center
Important Note: Windows normally blocks the content of .chm help files. When you open the file, you will only be able to see the navigation tree, but no content! To enable the contents: Store the .chm file on a local folder (not a network drive)
In the file explorer, right-click onto the file, and open the Properties dialog
Press the Unblock button.
