First of all, this is the result of tdx-info:
Software summary
Bootloader: U-Boot
Kernel version: 6.6.94-7.3.0-g7642ad324113 #1-Torizon SMP PREEMPT Thu Jul 3 08:47:26 UTC 2025
Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/e54388c03b414f15de5038757766a36da4957b04d84c897e8d44a069401c4dec/0
Distro name: NAME="Torizon OS"
Distro version: VERSION_ID=7.3.0-build.18
Distro variant: VARIANT="Docker"
Hostname: verdin-am62-15645571
Hardware info
HW model: Toradex Verdin AM62 WB on Verdin Development Board
Toradex version: 0075 V1.2A
Serial number: 15645571
Processor arch: aarch64
I’m trying to run an application that uses the JUCE framework on a Verdin AM62 module, but the problem I’m having is that none of the graphical interface elements are drawn inside the window.
I believe I’ve identified the cause — it seems there’s an issue with the graphics server, since when I run the glxinfo command, I get the following response:
# su - torizon -c glxinfo
name of display: :0
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 149 (GLX)
Minor opcode of failed request: 24 (X_GLXCreateNewContext)
Value in failed request: 0x0
Serial number of failed request: 35
Current serial number in output stream: 36
Meanwhile, on another module I have (Verdin iMX8M Plus WB), my application works correctly and the glxinfo command returns valid data:
# su - torizon -c glxinfo | head -n 40
name of display: :0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
GLX_ARB_context_flush_control, GLX_ARB_create_context,
GLX_ARB_create_context_no_error, GLX_ARB_create_context_profile,
GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_get_drawable_type, GLX_EXT_libglvnd, GLX_EXT_no_config_context,
GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_MESA_copy_sub_buffer, GLX_OML_swap_method, GLX_SGIS_multisample,
GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
GLX_SGI_make_current_read
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,
GLX_ATI_pixel_format_float, GLX_EXT_buffer_age,
GLX_EXT_import_context, GLX_EXT_no_config_context, GLX_EXT_swap_control,
GLX_EXT_swap_control_tear, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_INTEL_swap_event,
GLX_MESA_copy_sub_buffer, GLX_MESA_query_renderer, GLX_MESA_swap_control,
GLX_NV_float_buffer, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
I’d like to clarify that I ran the glxinfo command using the Qt example project (without any modifications from the Torizon IDE Extension template in VS Code) inside the container that runs that application and uses the “Torizon Application Container” qt6-wayland${GPU}.
This was done to ensure that the glxinfo tests couldn’t have been affected by any misconfiguration of the operating system or my Docker containers.
What could be the problem on the AM62 module?
Thank you very much!
Eng. Juan Pablo Ciciarelli
