I’m working with Colibri IMX6 Solo 256MB (Toradex BSP 2.4) .
Our base board has 3 codecs sgtl5000.
- 1 Codec - Colibri IMX6 Solo 256MB
- 2 Codecs - Base Board
The SoM’s Codec and 1 of the main board (SSI2) is working fine but the second (SSI3) one freeze when start the aplay/arecord.
The i2c is working good, I can see all the codecs attached at i2c bus.
- Codec 1 (SoM) - SSI1 I2C-2 - Working Ok
- Codec 2 (Base Board) - SSI2 - I2C-4 - Working OK
- Codec 3 (Base Board) - SSI3 - I2C-1 - Not Working
I’m suspecting a problem in my devicetree
root@colibri-imx6:~# aplay /usr/share/sounds/mysound/ringtone1.wav -V mono -Dhw:2,0
Playing WAVE '/usr/share/sounds/mysound/ringtone1.wav' : Signed 16 bit Little Endian, Rate 32000 Hz, Stereo
Hardware PCM card 2 'imx6-colibri-sgtl5000' device 0 subdevice 0
#######+ | 12%^CAborted by signal Interrupt...
root@colibri-imx6:~# Write failed: Broken pipe
I’m using kernel 3.10.17 with some modification in sgtl5000 drivers to support more than 1 codec.
In attached are the logs and the devicetree modification.
link text
Someone has an advice to debug this problem?
Thank you very much.
Caio Pereira
