I have problem setting up ACM v2.0B with Apalis iMX6 using yocto project. I’m going through How to use Analogue Camera Adapter on Embedded Linux but no success.
$modprobe adv7280_tvin
result:
[ ] adv7280 1-0021: chip found @ 0x42 (21a8000.i2c)
[ ] adv7280 1-0021: no sensor pwdn pin available
[ ] adv7280 1-0021: error resetting adv7280
and when I hold reset button on module and repeat
result:
[ ] adv7280 1-0021: adv7280_probe:Analog Device adv7280 not detected -6!
and gstreamer shows this error:
$gst-launch-1.0 imxv4l2videosrc device=/dev/video0 ! imxipuvideosink use-vsync=true
result:
[ ] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
Setting pipeline to PAUSED …
[ ] mxc_sdc_fb fb@1: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
ERROR: Pipeline doesn’t want to pause.
ERROR: from element /GstPipeline:pipeline0/GstImxV4l2VideoSrc:imxv4l2videosrc0: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Additional debug info:
…/git/libs/gst/base/gstbasesrc.c(3468): gst_base_src_start (): /GstPipeline:pipeline0/GstImxV4l2VideoSrc:imxv4l2videosrc0:
Failed to start
Setting pipeline to NULL …
Freeing pipeline …
