in VS code when I try to run pytest in debug mode, the Torizon extension is trying to reach some devices and run the debug code there.
I don’t think this is the proper behaviour, is there a way to fix it?
Rocco
Rocco
Hi @RoccoBr ,
The Torizon extension allows you to do remote-rebugging on the devices. So you can write code and test it immediately on the devices.
Would it be possible for you to elaborate a bit more on what behaviour you are seeing, as well as what you are expecting?
Do you have screenshots of the behavior you’re seeing?
Kevin
hi @kevin.tx ,
pytest framework is supposed to run inside VScode only, not on an actual device
Rocco
Hi @RoccoBr !
Could you please share the following information:
I’m using VS code v1.69.1 (latest) on Windows machine. toradex torizon support v1.5.1.
I can’t give you a project because you need first to configure pytest manually in your VScode environment (see previous link how to configure it Python testing in Visual Studio Code), but to reproduce the error is quite straightforward:
you will see that the Torizon extension will try to run the code on a device, when instead it shouldn’t interfere at all with the pytest framework
if you are more comfortable with unittest instead of pytest, you can reproduce the same wrong behaviour using the same step above
Rocco
Hi @RoccoBr, how are you?
I wanted to let you aware that we are currently trying to reproduce this on our side with the help of our colleagues from the extension team and we’ll come back to you once we have proper news.
hi @gclaudino.tx ,
more details in order to reproduce the error:
create a simple application (docker container) that you can run in debug mode on an actual SOM via torizon Extension
configure pytest in VS code and create a simple test as explained before.
Rocco
hi @gclaudino.tx ,
we have found a temporary workaround disabling the Torizon plugin in the extensions list and rebooting VS code, at that point we can run pytest in debug mode.
nevertheless, it would be better that Torizon extension doesn’t interfere with the pytest framework.
Rocco
Hi @RoccoBr,
Thanks for the updates. I’ve also forwarded them to the responsible team that is working on it.
I just got new feedback from our IDE Extensions Team. They investigated the topic and the issue is that when one creates a Torizon project with VSCode there are some Workspace configurations that are made even before executing the launch.json
. The extension understands by default that you want to run the code on the device and this is the origin of the issue you presented.
Therefore, the team has thought of two paths for you at the moment:
Would any of these two options be suitable for you? What do you think about it?
hi @gclaudino.tx ,
thanks for the support. I think the simplest thing is to disable the extension when I need to run pytest in debug mode.
Rocco
