I am working with a Colibri imx7d 512MB on an Iris v2 board. I’m trying to reassign pins on the X16 connector to act as gpio-keys. But Something is not working as expected.
One example is that I was asked to use X16/SODIMM pins 29/32 and 30/34 which by default belong to uart2. So in my dts file:
&iomuxc {
* Redefine the UART2 pinout to be only a non-hardware flow controlled
* UART, we need pins
* MX7D_PAD_SAI2_RX_DATA__UART2_DTE_RTS 0x79
* MX7D_PAD_SAI2_TX_DATA__UART2_DTE_CTS 0x79
* for gpio-keys.
pinctrl_uart2: uart2-grp {
fsl,pins = <
MX7D_PAD_UART2_TX_DATA__UART2_DTE_RX 0x79
MX7D_PAD_UART2_RX_DATA__UART2_DTE_TX 0x79
/* Expand the gpio-keys pinctrl */
pinctrl_gpiokeys {
fsl,pins = <
MX7D_PAD_LPSR_GPIO1_IO01__GPIO1_IO1 0x19 /* SODIMM 1 */
MX7D_PAD_SAI2_RX_DATA__GPIO6_IO21 0x19 /* SODIMM 32 */
MX7D_PAD_SAI2_TX_DATA__GPIO6_IO22 0x19 /* SODIMM 34 */
/* Redefine UART2 as a simple UART with no hardware flow control. */
&uart2 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_uart2>;
assigned-clocks = <&clks IMX7D_UART2_ROOT_SRC>;
assigned-clock-parents = <&clks IMX7D_OSC_24M_CLK>;
/delete-property/uart-has-rtscts;
/delete-property/fsl,dte-mode;
/* Redefine gpio-keys */
gpio-keys {
compatible = "gpio-keys";
pinctrl-0 = <&pinctrl_gpiokeys>;
right_key {
label = "Right-key";
gpios = <&gpio6 21 (GPIO_ACTIVE_HIGH | GPIO_PULL_DOWN)>;
linux,code = <KEY_RIGHT>;
debounce-interval = <10>;
down_key {
label = "Down-key";
gpios = <&gpio6 22 (GPIO_ACTIVE_HIGH | GPIO_PULL_DOWN)>;
linux,code = <KEY_DOWN>;
But it turns out that the MX7D_PAD_SAI2_TX_DATA__UART2_DTE_CTS aka MX7D_PAD_SAI2_TX_DATA__GPIO6_IO22 keeps it’s pull-up as if it where still using the old configuration.
In order to update the dtb I’m using:
ubiupdatevol /dev/ubi0_1 imx7d-colibri-iris-v2-myproject.dtb
I have decompiled the aforementioned dtb with
dtc --sort -I dtb -O dts imx7d-colibri-iris-v2-myproject.dtb -o myproject.dts
And reviewed the final codes for the pinmuxing and uart2 assignments, diffed it against the original iris-v2 decompiled dtb and everything seems fine..
What can I be missing?
