After running opkg update I am trying to install openjdk-8. There are problems with the version of libc6 but I am unable to upgrade that package as well. There appears to be two versions of libc (2.22-r0.3 and 2.22-r0) available in the repo but I don’t know if that is related to the issues I am having.
[root@lx2000-05 ~]# cat /etc/angstrom-version
Angstrom v2015.12 (Core edition)
Built from branch: HEAD
Revision: 1f4bfa33073584c25396d74f3929f263f3df188b
Target system: arm-angstrom-linux-gnueabi
[root@lx2000-05 ~]# opkg install openjdk-8
Installing openjdk-8 (72b05-r0.0) on root.
Not selecting libc6 2.22 as installing it would break existing dependencies.
Collected errors:
* satisfy_dependencies_for: Cannot satisfy the following dependencies for openjdk-8:
* libc6 (>= 2.22) * libc6 (>= 2.22) *
* opkg_install_cmd: Cannot install package openjdk-8.
[root@lx2000-05 ~]# opkg list | grep libc6
libc6 - 2.22-r0.3 - GLIBC (GNU C Library) The GNU C Library is used as the system C library
libc6 - 2.22-r0
[root@lx2000-05 ~]# opkg list_installed | grep libc6
libc6 - 2.22-r0
libc6-thread-db - 2.22-r0
[root@lx2000-05 ~]# opkg upgrade libc6
Assuming locally installed package libc6 (2.22-r0) is up to date.
You may need to force downgrade and force dependencies due to faulty non-standard versioning used by the upstream Linaro packages:
opkg install --force-downgrade --force-depends openjdk-8
You may anyway find that openjdk-8 installs correctly despite complaints about not selecting packages that would break existing dependencies.
Thank you Brandon for the quick reply.
Unfortunately this did not work for me.
[root@lx2000-05 ~]# opkg install --force-downgrade libgcc1 libc6
Package libgcc1 (linaro-5.2-r2015.11-2) installed in root is up to date.
Unknown package 'libc6'.
Collected errors:
* opkg_install_cmd: Cannot install package libc6.
adding “–force-depends” will likely resolve this issue, let me know if that works
adding “–force-depends” worked to upgrade libc6 but installing opendjk-8 still failed unless I added “–force-depends” to that install as well.
I now have libc6 - 2.22-r0.3 and opendjk-8 installed.
Right now it seems I am able install packages but only if I add “–force-depends” for all the opkg installs or upgrades.
@dhammer Thanks for the feedback, I will update the answer accordingly. I apologize for the issue here. Unfortunately, the upstream Angstrom repositories have built packages with different builds of the same c/gcc versions as our image. This should hopefully be cleared up by the next Angstrom release that we build on.
