Problem in recovery mode for VF50
I’m trying to recover two modules VF50.
I use the image version 2.5 to recovery.
When I do this, I always follows the topic of recovery mode from scratch:
http://developer1.toradex.com/knowledge-base/flashing-linux-on-vybrid-modules#Flashing_from_Scratch
Follow my log:
$ sudo ./update.sh -n -d /dev/ttyUSB0
Colibri VF rootfs detected
Put the module in recovery mode and press [ENTER]...
config file <vf_flash/vybrid_usb_work.conf>
parse vf_flash/vybrid_usb_work.conf
starting associating phase
association phase succeeded, response was 0x23454523
HAB security state: development mode (0x56787856)
== work item
filename colibri-vf_bin/u-boot.imx
load_size 0 bytes
load_addr 0x00000000
dcd 1
clear_dcd 0
plug 1
jump_mode 2
jump_addr 0x00000000
== end work item
main dcd length 8
sub dcd length 4
loading binary file(colibri-vf_bin/u-boot.imx) to 3f4078e8, skip=0, fsize=67718 type=aa
<<<423704, 423704 bytes>>>
succeeded (status 0x88888888)
jumping to 0x3f4078e8
After that, I’m able to access the console again.
Colibri VFxx # nand erase.chip
NAND erase.chip: device 0 whole chip
Skipping bad block at  0x013c0000
Skipping bad block at  0x07f80000
Skipping bad block at  0x07fa0000
Skipping bad block at  0x07fc0000
Skipping bad block at  0x07fe0000
OK
Colibri VFxx # run setupdate
reading flash_blk.img
1719 bytes read in 13 ms (128.9 KiB/s)
## Executing script at 80008000
enter "run update" to update the entire module
Colibri VFxx # run create_bcb
NAND erase.part: device 0 offset 0x0, size 0x20000
Erasing at 0x0 -- 100% complete.
OK
Write FCB...
FCB 2048 bytes written to 0x0: OK
Colibri VFxx # cfgblock create
Is the module an IT version? [y/N] y
Enter the module version (e.g. V1.1B): V1.2A
Enter module serial number: 04887763
Toradex config block successfully written
Colibri VFxx # run update
reading u-boot-nand.imx
453400 bytes read in 47 ms (9.2 MiB/s)
NAND erase.part: device 0 offset 0x20000, size 0x160000
Erasing at 0x160000 -- 100% complete.
OK
NAND erase.part: device 0 offset 0x180000, size 0x80000
Erasing at 0x1e0000 -- 100% complete.
OK
NAND write: device 0 offset 0x20000, size 0x160000
 1441792 bytes written: OK
reading ubifs.img
47108096 bytes read in 3063 ms (14.7 MiB/s)
UBI: default fastmap pool size: 50
UBI: default fastmap WL pool size: 25
UBI: attaching mtd1 to ubi0
UBI: scanning is finished
UBI: empty MTD device detected
UBI: attached mtd1 (name "mtd=3", size 126 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 1003, bad PEBs: 5, corrupted PEBs: 0
UBI: user volume: 0, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 0
UBI: available PEBs: 982, total reserved PEBs: 21, PEBs reserved for bad PEB ha5
No size specified -> Using max size (124690432)
Creating dynamic volume rootfs of size 124690432
47108096 bytes written to volume rootfs
resetting ...
This is my problem, I receive the message “resetting…”, but nothing happens.
In this point I’m not able to type any command. If I try reset the module by hardware I need to run the recovery mode again. The same happens if I try to turn OFF and ON the evaluation board.
What I’m doing wrong? It’s always works to me.
Thank you very much!
@witte, everything appears correct. At the very end after “resetting…” you will need to do a hardware reset/power cycle which it sounds like you have attempted. Perhaps you can try powering off and completely removing power from the board for 5+ seconds. Then try powering back on.
If it seems that the system is still is not booting, check if the module is still in recovery mode. For example, try running the update.sh -d script. If the module is still in recovery mode, then I suppose there are a few unusual ways which that could happen - perhaps the recovery mode button on the eval board is somehow stuck. Do you happen to have a 2nd carrier board?
Note that you need to powercycle the module after the update. A reset does not take the module out of the recovery mode.
@brandon.shibley and @stefan.agner,
I think the image I used was corrupted for some reason. I rebuild all and the end of the process I cut off the power. Now it works perfectly.
I apreciate your support!!!
Thank you!
