i’d like to setup a development system for my target which boot from tftp/nfs.
Additional i want to use static ip’s for target/host to avoid the usage of dhcp.
( nfs is working from userspace/ tftp is working from BL & userspace )
The Problem is that the rootfs is not mounting via nfs during booting. I get errors like this:
[ 17.094919] VFS: Cannot open root device “169.254.10.1:rootfs/” or unknown-block(0,0): error -6
[ 17.105857] Please append a correct “root=” boot option; here are the
available partitions:
[ 17.190222] Kernel panic - not syncing: VFS: Unable to mount root fs on
unknown-block(0,0)
… crash & backtrace
setup
A using the binaries from toradex => Apalis_iMX6_LinuxImageV2.6
→ uImage → uImage–3.14.52-r0-apalis-imx6-20160629134804.bin
→ uImage-imx6q-apalis-ixora.dtb → uImage–3.14.52-r0-imx6q-apalis-ixora-20160629134804.dtb
B tftp/nfs dirs are located @ /srv/tftp resp. /srv/nfs/ and the daemons are started.
C move uImage and dtb (as imx6q-apalis-ixora.dtb) in /srv/tftp
D extract & move rootfs in /srv/nfs/rootfs
E using bootloader from previous installation ( via emmc update scripts ):
=> U-Boot 2015.04+fslc+ge1a48b2 (Mar 31 2016 - 01:27:13)
workflow @ BL:
set serverip/ipaddr/netmask
load kernel&dbt via tftp:
tftp 0x10800000 uImage; tftp 0x12000000 imx6q-apalis-ixora.dtb -
adjust bootargs ( tried some settings) :
Kernel command line:
enable_wait_mode=off vmalloc=400M
ip=169.254.10.2:169.254.10.1:169.254.10.1:255.255.0.0:eth0:static
root=169.254.10.1:rootfs/ rw nfsrootdebug fec_mac=00:14:2d:4a:2b:1d
consoleblank=0 no_console_suspend=1 console=tty1 console=ttymxc0,115200n8 video=mxcfb0:dev=ldb
- booting:
bootm ${kernel_addr_r} - ${fdt_addr_r}
Q: what are the right settings for bootargs in my setup?
Q: i can’t find doc’s/ explanation about bootargs params like “netdevwait”.
Some hints will be helpful.
best regards
Lars
