Prevent black screen AND reduce display EMC emissions
Sorry @alex.tx, I may have misspelled it.
I was referring to the fact that UseSplashSettings = 1 seems necessary to avoid Prevent Black Screen Between Splash Screen And Application.
I will try to reword my issue: turns out, that while UseSplashSettings = 1, the value put in the “LCDBS” key is ignored; Also, i did not found an equivalent setting to use in the ss configblock, so i set UseSplashSettings = 0 for now, but it obviously made the black screen issue come back.
My first need is to keep LCDBS value the lowest possible to reduce EMC problems.
I would like to know if there is a solution to fix both issues, preventing black screen And using LCDBS registry value.
