I am using a Trimble Mini-T GNSS module which is connected to a custom carrier board with an Apalis iMX6Q module. I am trying to get the PPS from the GNSS to the Apalis module for accurate time. I have added these lines to my device tree
pps {
compatible = "pps-gpio";
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_pps>;
gpios = <&gpio2 4 GPIO_ACTIVE_HIGH>;
&iomuxc {
pinctrl_pps: pps {
fsl,pins = <
MX6QDL_PAD_NANDF_D4__GPIO2_IO04 0x130b0
When i boot the module, it appears that the pps module is being created and assigned… well actually it looks like 3 of them are
root@acu3:~# dmesg |grep pps
[ 0.238628] pps_core: LinuxPPS API ver. 1 registered
[ 0.238632] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.471134] pps pps0: new PPS source ptp0
[ 0.493930] pps_ldisc: PPS line discipline registered
[ 0.494529] pps pps1: new PPS source pps.-1
[ 0.494761] pps pps1: Registered IRQ 118 as PPS source
[ 16.751466] pps pps2: new PPS source IMX-uart4
[ 16.751554] pps pps2: source "/dev/ttymxc4" added
The GPS works perfectly using gpsd’s ‘cgps’ and when I scope the PCB trace, I can see the PPS signal so I know that it is reaching the pin. However when I run ‘ppstest’ I get nothing.
root@acu3:~# ppstest /dev/pps1
trying PPS source "/dev/pps1"
found PPS source "/dev/pps1"
ok, found 1 source(s), now start fetching data...
time_pps_fetch() error -1 (Connection timed out)
^C
root@acu3:~# ppstest /dev/pps0
trying PPS source "/dev/pps0"
found PPS source "/dev/pps0"
^C
root@acu3:~# ppstest /dev/pps2
trying PPS source "/dev/pps2"
found PPS source "/dev/pps2"
^C
Any thoughts as to what the issue might be. I am using ntpd for timing and it isnt working correctly but I feel that is due to the system not recognizing the PPS signal.
