Possible bug in VSC extension early access
When removing a device from the device list it removes that device and all the devices below it in the list, see attached images where I click on the - symbol next to item 6.
I can see config.yaml loses the lines as well. When I paste them back into config.yaml I have to restart to get them picked up.
Ed
Greetings @edwaugh,
This is a known issue and was reported to us very recently. Please allow us some time to investigate and devise a fix for this. Thank you reporting however, we appreciate it.
Is this an item on the feature list somewhere? Would be good if there was some visibility of what is planned.
The related issue/ticket can be followed here: Torizon IDE Extensions Issue Tracker
However I checked internally and the bug was fixed, we just haven’t published a new official release yet. Though the fix might be available in the latest early access version of the extension. Could you give this a try?
