Is it possible to port ubuntu on Colibri iMX6 DualLite 512MB board and run it from eMMC card (without SD-card)? If yes , what are the steps for doing the same.
Thanks,
Kaustubh
Thanks,
Kaustubh
Toradex does not offer an official guide to port Ubuntu to i.MX6; however, you may follow the guide provided by NXP.
Be sure to use the Toradex U-boot & kernel and build for Colibri iMX6
Thanks for the answer. Is it possible to install ubuntu filesystem from SD-card to eMMC memory on the board?
Thanks,
Kaustubh
Yes. Once you have the rootfs per Brandon’s link have a look at the following post.
Max
