Hello!
In Morty (Toradex 2.7, kernel 4.1) we used device tree overlays to support different displays (Toradex introduced them later).
After porting to Dunfell (Toradex 5.x.y, kernel 5.4), the split-mode does not work anymore, there is no image at all.
Smaller displays (single channel LVDS) and HDMI work fine.
In split-mode, there is a signal on the LVDS output lines, but it looks wrong on the oscilloscope. So there seems to be a problem with the clock / data generation.
The resulting frame buffer configuration looks correct for me:
mode "1920x1080-60"
# D: 142.005 MHz, H: 66.669 kHz, V: 60.062 Hz
geometry 1920 1080 1920 1080 32
timings 7042 100 100 10 10 10 10
accel false
rgba 8/16,8/8,8/0,8/24
endmode
The device tree of the running system (dtbo applied):
dunfell.dts (91.4 KB)
The configured display is “g156hcel01”, not “1920x1080”
Any suggestion?
Thanks!
