[poky] Missing glxext.h header file in core-image-x11 // toolchain SDK
hi,
I have generated a core-image-x11 image for a Toradex Colibri T20 board.
I aim to compile and execute our application that normally runs under X11 + OpenGL.
*Please note I’m not an expert of X11 .:slight_smile: *
Therefore, I need to have the necessary libraries in the linux image I have generated.
I have therefore added in my local.conf:
DISTRO_FEATURES_append = "opengl"
In order to compile our application, I have generated the respective toolchain with bitbake -c populate_sdk core-image-x11.
It worked fine as well.
But as I launched the makefiles, I got some
...xxx.cpp :188:25: fatal error: GL/glxext.h: No such file or directory
   #include <GL/glxext.h>
Indeed, I have no glxext.h file in the generated toolchain sdk, neither in the sysroots.
In my sysroot, I have only:
./GL
β”œβ”€β”€ glxint.h
β”œβ”€β”€ glxmd.h
β”œβ”€β”€ glxproto.h
β”œβ”€β”€ glxtokens.h
└── internal
    └── glcore.h
./GLES
β”œβ”€β”€ egl.h
β”œβ”€β”€ glext.h
β”œβ”€β”€ gl.h
└── glplatform.h
./GLES2
β”œβ”€β”€ gl2ext.h
β”œβ”€β”€ gl2.h
└── gl2platform.h
So, I suppose that something is missing in the features of my core-image-x11 (and subsequently in the respective toolchain).
Should I add something in some features ?
Cheers,
Karim
Hi
The Colibri T20 only supports HW accelerated 3D rendering with the Open GL ES 1.1 and Open GL ES 2 variant.
So we fiddle with the OE mesa recipe to exclude desktop OpenGL.
While one probably could get software rendered OpenGL to run the results will likely be disappointing.
Also I’m expect a lot of pitfalls if you try to configure OpenEmbedded/Yocto to build a image with software rendered OpenGL mixed with hardware accelerated OpenGL ES.
Max
Hi Max,
That’s indeed right.
I setup our application makefile options to activate GLES with GTK support instead of glx..
It finally works fine !
Thanks.
Karim
