Plymouth with BSP 7.0.0
root@verdin-imx8mp-15335644:~# tdx-info
Software summary
Bootloader: U-Boot
Kernel version: 6.6.23-7.0.0-devel-g905d86e4202a #1 SMP PREEMPT Wed Sep 25 11:25:16 UTC 2024
Kernel command line: root=PARTUUID=b9ba28e5-02 ro rootwait console=tty1 console=ttymxc2
Distro name: NAME=“TDX Wayland with XWayland”
Distro version: VERSION_ID=7.0.0-devel-20241219010323-build.0
Hostname: verdin-imx8mp-15335644
Hardware info
HW model: Toradex Verdin iMX8M Plus on Verdin Development Board
Toradex version: 0063 V1.1B
Serial number: 15335644
Processor arch: aarch64
I am attempting to migrate to BSP 7.0.0 and need to add my Plymouth splash screen. I have followed the directions on:
Unfortunately, I am receiving the following error:
ERROR: plymouth-24.004.60-r0 do_compile: ExecutionError(‘/home/sutter/oe-core/build/tmp/work/armv8a-mx8mp-tdx-linux/plymouth/24.004.60/temp/run.do_compile.11740’, 1, None, None)
Is this a known issue?
It seems you’re encountering a compilation error while trying to add a custom Plymouth splash screen on BSP 7.0.0 for your Verdin iMX8M Plus. While this specific error isn’t widely recognized as a known issue, there are several steps you can take to troubleshoot and resolve it:
  1. Check the Error Logs: Examine the detailed logs generated during the compilation process. These logs can provide specific insights into what might be causing the error.
  2. Verify Dependencies: Ensure that all necessary dependencies for Plymouth are installed in your build environment. Missing dependencies can often lead to compilation failures.
  3. Configuration Settings: Double-check your configuration settings in the Yocto build environment. Ensure that any modifications made for Plymouth are correctly applied and compatible with BSP 7.0.0.
  4. Yocto Build Environment: Confirm that your Yocto build environment is set up correctly for BSP 7.0.0. Issues can sometimes arise from misconfigurations or outdated components in the build setup.
  5. Consult Documentation: Revisit the specific instructions for adding a splash screen in the context of BSP 7.0.0. There might be version-specific steps or considerations that need to be addressed.
By following these steps, you should be able to identify and resolve the issue causing the compilation error. If the problem persists, consider reviewing any recent changes made to the build environment or configurations that might have introduced the error.
Toradex AI Assistant
Verdin iMX8M Plus - Splashscreen.
Hey @Sutter99,
There has been some issues with splash screens that have been fixed with 7.1.0 nightly pre-release. Are you able to try this?
-Eric
Hi @eric.tx,
I had been using 7.1.0 but had to revert to 7.0.0 because my MIPI-CS camera would not function with 7.1.0. This was described in the thread below:
Would it be possible for me to patch the changes into 7.0.0?
Thank you
Hi @eric.tx,
I built 7.1.0-devel-20250107175416+build.0 and added Plymouth. Unfortunately, it produces the error in the attached log.
ERROR plymouth-24.004.60-r0 do_comp.txt (117.0 KB)
Hey @Sutter99,
Currently have a build trying with 7.1.0 and some of the errors are the same as your link [see below]. There have been some known issues with Plymouth and Torizon that were corrected with 7.1.0, but not on the BSP only side. I will see if my team can share with me any more information.
| ../plymouth-24.004.60/src/plugins/splash/script/script-object.c: In function 'script_obj_as_string':
| ../plymouth-24.004.60/src/plugins/splash/script/script-object.c:314:17: warning: ignoring return value of 'asprintf' declared with attribute 'warn_unused_result' [-Wunused-result]
|   314 |                 asprintf (&reply, "%g", string_obj->data.number);
| ../plymouth-24.004.60/src/plugins/splash/script/script-object.c:319:9: warning: ignoring return value of 'asprintf' declared with attribute 'warn_unused_result' [-Wunused-result]
|   319 |         asprintf (&reply, "#(0x%p)", obj);
| ../plymouth-24.004.60/src/plugins/splash/script/script-object.c: In function 'script_obj_plus':
| ../plymouth-24.004.60/src/plugins/splash/script/script-object.c:531:25: warning: ignoring return value of 'asprintf' declared with attribute 'warn_unused_result' [-Wunused-result]
|   531 |                         asprintf (&newstring, "%s%s", string_a, string_b);
Hey @Sutter99,
I’m testing the build now, but there may be some corrections in the bbappend file required.
Spacing changes in the PACKAGECONFIG and the removal of --with-udev
FILESEXTRAPATHS:prepend := "${THISDIR}/files:"
SRC_URI += " \
    file://torizonlogo-white.png \
    file://spinner.plymouth \
PACKAGECONFIG = " pango drm "
EXTRA_OECONF += "--with-runtimedir=/run"
do_install:append () {
    install -m 0644 ${WORKDIR}/torizonlogo-white.png ${D}${datadir}/plymouth/themes/spinner/watermark.png
    install -m 0644 ${WORKDIR}/spinner.plymouth ${D}${datadir}/plymouth/themes/spinner/spinner.plymouth
-Eric
Hi @eric.tx,
The error is still present with the bbappend you provided with 7.1.0-devel-20250107175416+build.0.
Hey @Sutter99,
Some corrections.
SRC_URI += " \
removal of the package config requirement, and this causes the need to add
meta-initramfs to the bblayers.conf file.
This allows me to build successfully.
-Eric
Hi @eric.tx,
Thank you! That worked on 7.1.0-devel-20250107175416+build.0. I will need to test it on 7.0.0 next.
Hi @eric.tx,
With your changes Plymouth now functions in 7.0.0 as well.
Thank you!
After further testing, I need to update this thread for use with Plymouth (24.004.60) used in Scarthgap.
I had originially started with the following which worked for Kirkstone but failed to build in Scarthgap.
SRC_URI += " \
    file://sutter_logo.png \
PACKAGECONFIG = "pango drm"
EXTRA_OECONF += "--with-udev --with-runtimedir=/run"
    install -m 0644 ${WORKDIR}/sutter_logo.png ${D}${datadir}/plymouth/themes/spinner/watermark.png
Based on this thread, I started using the following directives.
Unfortunately, this showed the splash screen inconsistently.
I am now using the following directives and have not had a failure to show the splash screen on boot.
PACKAGECONFIG:append = " pango drm"
I think the removal of PACKAGECONFIG = “pango drm” was necessary initially in Scarthgap because we were passing items to EXTRA_OECONF which is a part of autotools and this version of Plymouth is built with meson. Removing addition of items to EXTRA_OECONF allowed the re-addition of the PACKAGECONFIG items.
