plymouth boot animation and initramfs
i posted a lot of topics about plymouth but still can’t find the right solution the animation doesn’t have a stable behavior i mean it can be killed at different points each time and still can’t figure out the problem isn’t about the script the frames or services management
for the services i only changed two weston.service by adding
# If Plymouth is used, we want to start when it is on its way out.
After=plymouth-quit-wait.service plymouth-quit.service
and plymouth-quit.service by adding a delay
[Service]
ExecStartPre=/bin/sleep 8
for the scripts i worked with a ready templates from a github project
https://github.com/adi1090x/plymouth-themes
now all my services are getting slow literally slow the qt app takes extra time to be launched even the animation (if worked) is slower
can you please tell me what’s the problem
and do you think that i should try this solution : add initramfs and let it hold the task of showing the boot animation instead of the kernel
It sounds like you’re encountering issues with the Plymouth boot animation’s stability and the slow startup of services after modifying the weston.service and plymouth-quit.service. These changes might be affecting the boot sequence timing, leading to the behavior you’re observing.
Plymouth is designed to provide a graphical boot animation during the system boot process. It typically starts early, often from an initial minimal root file system (initramfs). Using initramfs to manage the boot animation can indeed help stabilize it by ensuring it starts early and consistently.
Here are some steps and considerations to address your issue:
  1. Service Dependencies and Timing:
    • Review the dependencies and timing of your services. The After=plymouth-quit-wait.service plymouth-quit.service directive ensures that weston.service starts after Plymouth has finished, but adding a delay with ExecStartPre=/bin/sleep 8 might be causing unnecessary delays. Consider adjusting or removing this delay to see if it improves startup times.
  2. Using Initramfs for Plymouth:
    • Torizon OS uses Plymouth within initramfs, which starts very early during the boot process. This setup can help ensure that the boot animation is consistent and less prone to interruptions.
    • You can customize the initramfs to include your specific Plymouth theme or settings. This involves creating a new OSTree commit with the customized initramfs.
  3. Troubleshooting Steps:
    • Check system logs for any errors or warnings related to Plymouth or the services you modified. This might provide insights into what is causing the instability.
    • Test with different Plymouth themes or configurations to see if the issue persists.
By addressing the service dependencies and considering the use of initramfs for Plymouth, you should be able to achieve a more stable boot animation and improve service startup times.
I hope this helps resolve your issue.
Overlap Docker and Plymouth services boot.
Hi @rania !
In your other topics, we managed to provide help regarding the Plymouth.
As already shared, Torizon OS has all you need already implemented: initramfs and Plymouth. So you can check study how it is done in Torizon OS’s recipes and replicate on your side.
If you need further assistance, since this is related to your specific development, best thing would be to reach out to some of Toradex Partners to develop more quickly (since you have invested quite some time on it).
Here the search is already filtered for Embedded Linux-related partners:
https://www.toradex.com/support/partner-network/services/os-customization/embedded-linux
