Please teach us GPIO supply voltlage on Colibri i.MX6
Please teach us GPIO supply voltlage (NVCC_CSI,etc) on Colibri i.MX6, voltage is 1.8 or 2.8 or 3.3?
We referenced for “i.MX 6Solo/6DualLite Applications Processors for Industrial Products (Table 8. Operating Ranges)”.
Regard,
Hi
The GPIO supply voltage for the pins available on X1 is 3.3V.
The Colibri iMX 6 datasheet provides additonal information on these pins including some pins having additional circuitry on the Colibri iMX6 board.
Regards
Max
Hi ,MAx
Thank you for your reply.
We referenced for 5.1.1 Digital Supply in the Colibri iMX 6 datasheet.
Regards
Hi
Please refer to the Viola carrier board datasheet and schematic. As most pins on headers are routed directly to the SoM connector you will then have to refer to the SoM datasheet as explained in the original answer.
Max
