Playing mp3 files in angstrom
I have a angstrom qt linux image on Col VF61. I need to play .mp3 files. For wav files and I am using aplay. In ubuntu I used to mpg123 to play .mp3 files but thats not available in angstrom. I do not have internet connectivity on Col VF61 so cannot download it. Is there any link from where I can download mpg123 (or any other .mp3 player) for angstrom and install its package in it. Is there any other alternative for it.
I am building an application where I am using QT. I tried using QTs QSound to play mp3 files but it gave me an error Failed to open audio device. So I thought if there is any internal linux command to play mp3 files then I can directly use it to play file. Please help. Thanks.
opkg update
opkg install gst-plugins-base-playbin gst-plugins-base-alsa gst-plugins-base-audioconvert gst-plugins-base-audioresample gst-plugins-ugly-mad
Install the required gstreamer plugins with opkg and then mp3 file can be played using gst-launch
from the command line.
gst-launch-0.10 filesrc location=Illusory.mp3 ! mad ! audioconvert ! alsasink
Check if the sound card is detected correctly
root@colibri-vf:~# cat /proc/asound/cards
 0 [Audio          ]: Colibri_VF61_AC - Colibri VF61 AC97 Audio
Sound cards are detected correctly. However I was trying to run the speakertest by running the command speakertest. It should speak something like Front Left or Front Right but there was a buzzing sound and nothing else. Is that the right command or I am doing something wrong
Why use speaker-test? Does aplay correctly plays a .wav file? And the noise would be expected as can be seen from it’s output “Using 16 octaves of pink noise”
root@colibri-vf:~# speaker-test
speaker-test 1.1.2
Playback device is default
Stream parameters are 48000Hz, S16_LE, 1 channels
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 4096 to 4096
Period size range from 1024 to 1024
Using max buffer size 4096
Periods = 4
was set period_size = 1024
was set buffer_size = 4096
 0 - Front Left
Time per period = 2.889012
 0 - Front Left
Time per period = 2.986463
 0 - Front Left
yes aplay works fine with wav files. Currently I do not have internet connectivity for Col VF61. Can I download all the packages which you have mentioned in my ubuntu and then copy it to VF61 to install it. Is it prossible. From where can I download them.?
You can download them from here. Note that you would have to do the dependency resolution if any, manually.
Please have a look here for the full command line of speakertest: High performance, low power Embedded Computing Systems | Toradex Developer Center
Thank You.
