Colibri iMX8XDX 1GB V1.0B
I’m using “Config Tools for i.MX Version 10.0” to create a .mex file which defines the pin settings for my application. Ball names “MIPI_DSI0_GPIO0_00” and “MIPI_DSI0_GPIO0_01” are being configured for ‘I2C_SCL’ and ‘I2C_SDA’. What would be the recommended bit settings for “SW_CONFIG” (bits 26-25)? Would ‘OPEN_DRAIN_INPUT’ (10b) be preferred over ‘INOUT’ (11b) since I2C uses Open Drain for drivers and receivers?
The same applies for “MIPI_DSI1_I2C0_SCL” and “MIPI_DSI1_I2C0_SDA”
