I saw on the web site Pin Multiplexing - Changing Pin Functionalities in the Linux Device Tree | Toradex Developer Center, there is a topic to change pin functionalities on dts file.
My question : I used pinout-designer to choose pin and functionnalities. I saved my configuration and I would like to know if it’s possible to use the XML file to generate dts file.
Regards
Franck
