Hi, I’m following the instruction of “How to use Gstreamer on Torizon OS”, in the last step where I run docker compose on the Colibri imx8, it says this error:
weston_1 | dos2unix: converting file /etc/xdg/weston/weston.ini to Unix format...
weston_1 | dos2unix: converting file /etc/xdg/weston-dev/weston.ini to Unix format...
weston_1 | Couldn't open /dev/tty1
weston_1 | /usr/bin/entry.sh: line 89: [: =: unary operator expected
weston_1 | NXP EULA has already been accepted.
weston_1 | touch: cannot touch '/tmp/nxp-eula-accepted': Permission denied
weston_1 | Date: 2023-11-23 UTC
weston_1 | [15:08:23.270] weston 9.0.0
weston_1 | https://wayland.freedesktop.org
weston_1 | Bug reports to: https://gitlab.freedesktop.org/wayland/weston/issues/
weston_1 | Build: 9.0.0
weston_1 | [15:08:23.270] Command line: /usr/bin/weston
weston_1 | [15:08:23.270] OS: Linux, 5.4.193-5.7.2+git.b60d3160f
what should I do to resolve this? Thank you!
