Is it possible to permanently store Easy Installer in a separate partition and boot from that partition when required?
The idea is to be able to re-flash the module by instructing U-boot to boot from the tezi partition.
Thanks.
Thanks.
hi @iliaspat
Yeah, this is possible however it is not supported by our demo and Toradex Easy Installer images. In general, the demo images and Toradex Easy Installer images have a predefined partition scheme So you will need to create a custom OS Image and a customised Toradex Easy Installer Image.
To do this, we would recommend you to use SD boot or TFTP boot and then boot the Toradex Easy installer image. This would also save space on the module.
Best regards, Jaski
Do you have plans to make a how to build this custom Easy Installer Image?
I would also find it helpful to have a Easy Installer Image that could be started from SD or TFTP.
What is your application? You can a look here to get the meta layer of toradex easy installer. I hope it helps you.
This is already possible. Its like booting from SD or TFTP.
