we are migrating from SOM module VF50 to i.MX6ULL and I’ve noticed that cat /proc/cpuinfo reports significantly worse BogoMIPS for module i.MX6ULL ( even driven at higher freq. ) than for VF50.
Our image is based on tdx-reference-minimal-image with some changes due to custom carrier board.
So I want to ask if performance of iMX6ULL is correct (i.e. it is really lower than on VF50 module), or shall we look for an issue with build kernel?
Values reported for VF50:
cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 1 (v7l)
BogoMIPS : 262.96
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 vfpd32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc05
CPU revision : 1
Hardware : Freescale Vybrid VF5xx/VF6xx (Device Tree)
Revision : 0000
Serial : 02928057
Values reported for iMX6ULL:
cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 5 (v7l)
BogoMIPS : 64.00
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 5
Hardware : Freescale i.MX6 Ultralite (Device Tree)
Revision : 0000
Serial : 07130558
Report from cpufreq-info for iMX6ULL:
cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to cpufreq@vger.kernel.org, please.
analyzing CPU 0:
driver: imx6q-cpufreq
CPUs which run at the same hardware frequency: 0
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: 86.0 us.
hardware limits: 198 MHz - 528 MHz
available frequency steps: 198 MHz, 396 MHz, 528 MHz
available cpufreq governors: conservative, userspace, powersave, ondemand, performance
current policy: frequency should be within 198 MHz and 528 MHz.
The governor “performance” may decide which speed to use
within this range.
current CPU frequency is 528 MHz (asserted by call to hardware).
cpufreq stats: 198 MHz:0.57%, 396 MHz:1.14%, 528 MHz:98.29% (458)
Thank you.
