Dear all,
i’m working with the following configuration:
Apalis iMX8QM 4GB WB IT V1.1D
Ixora Carrier Board V 1.2A
Linux BSP 6.3.0
I want to improve to enable firmware load through PCIe.
When I try to run the PCIe-driver, I get the following error on the MSI interrupt:
[ 7.054120] hailo: Init module. driver version 4.14.0
[ 7.061908] hailo 0000:01:00.0: Probing on: 1e60:2864...
[ 7.067360] hailo 0000:01:00.0: Probing: Allocate memory for device extension, 11560
[ 7.075267] hailo 0000:01:00.0: enabling device (0000 -> 0002)
[ 7.081418] hailo 0000:01:00.0: Probing: Device enabled
[ 7.087261] hailo 0000:01:00.0: Probing: mapped bar 0 - 00000000f0597a86 16384
[ 7.095030] hailo 0000:01:00.0: Probing: mapped bar 2 - 00000000e13bb78e 4096
[ 7.102272] hailo 0000:01:00.0: Probing: mapped bar 4 - 00000000ed13a7a2 16384
[ 7.109582] hailo 0000:01:00.0: Probing: Setting max_desc_page_size to 4096, (page_size=4096)
[ 7.121403] hailo 0000:01:00.0: Probing: Using driver allocated vdma buffers
[ 7.128533] hailo 0000:01:00.0: Probing: Enabled 64 bit dma
[ 7.134164] hailo 0000:01:00.0: Disabling ASPM L0s
[ 7.139085] hailo 0000:01:00.0: Successfully disabled ASPM L0s
[ 7.145041] hailo 0000:01:00.0: Failed to enable MSI -22
[ 7.150411] hailo 0000:01:00.0: Failed Enabling interrupts -22
[ 7.156314] hailo 0000:01:00.0: Failed activating board -22
[ 7.156468] hailo: probe of 0000:01:00.0 failed with error -22
Can someone help me with this, pls?
